Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone elses topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when its posted at the end of someone elses topic. And those answers will be specific to your particular issue.
See more
See less
Pictures of old Evinrudes
  • Pictures of old Evinrudes
    Hi,Could anyone tell me if available, and where I could find pictures of the Evinrude Modells from the 60-70´s ? I myself have a 40hp from probably the 60*es, but I´m not sure. Thanks in advanceMatt, Sweden
    Re: Pictures of old Evinrudes
    http://www.pfs-ware.com/OtherAds/index.htm Matt, this will get you to some kicker scans from the 50-60's. www.AOMCI.com is the antique outboard club. Go to their links page and start looking. You'll probably find something to match. ORPost the model number here and I'll tell you what year the engine is. Evinrudes will have the model number on a plate thats attached to the transom mounting bracket just above the lock down latch. The first 5 numbers are the model number the second set of numbers are the serial number. If the plate is missing remove the engine cover and find the freeze plug on the top of the powerhead. They also will be stamped with these numbers.
    • #3
      I have a late 50's to early 60's 35hp ev. It is black & red with lots of crome. its a good motor and only needs minor repairs to make it run.What do you need to know about these motors?see yeah
