• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Johnson/ evinrude Jet drive lowers?
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Johnson/ evinrude Jet drive lowers?
    I have been offerd a "OMC JET DRIVE LOWER" for my '77-140. anyone know anything about these? It looks really cool!!Thanks, as always. Dave
    Re: Johnson/ evinrude Jet drive lowers?
    Hi Dave, A jet drive uses an internal impeller to draw water into a thrusting chamber, where it is forced out at a high velocity to propel the boat. These units have advantages, boating in shallow areas, lower unit not as deep to hit something. There are also some disadvantages, the jet drive is not as quick to respond to increased throttle speeds and the top end will not be as high as a propeller lower. They usually use more fuel to go the same distance as a propeller lower unit.
    • #3
      Rule of thumb jet drives cut HP. in half. CHawk
      • #4
        So it comes down to how cool you want to look vs how fast you want to go?.. I must say it looks Very cool.Check it outhttp://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1105215518
        • #5
          Let me know if you want to sell, if you are not going to use, if you are what do you want for your lowerunit , contact me at918-786-8180fmrs@greencis.net
