• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
1969 Johnson out board 55hp, wont prime
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1969 Johnson out board 55hp, wont prime
    Hi everyone, great site glad to be a part of it. Hope you can help me with this problem. I have a 55 horse 1969 johnson 3cyl. Was running great. Now for some reason it wont prime, keep in mind this was last summer, I put it away because of this problem. When I squeeze the prime ball, it never gets hard and eventually gas dumps out the carbs. I bought a new baulb, same thing, and, whan im running it it chocks out, sound like the floats? Im not very mechanically inclined so if it is, is it somthing I could do myself.
    Re: 1969 Johnson out board 55hp, wont prime
    Can never be sure but if it was mine i would dis assembley carub and do a through cleaning along with kit and try it again. seems like a carub problem to me.
    • #3
      thanks for the tip, thats what im trying to avoid, if I can, the moter was tuned up last year and they checked and cleaned the carbs.They said it would be 100$ just to look at it again, and wont give me any info over the phone. I did just find however a small crack in a line hooked to the bottom carb, but it looked like it was on far enough to not be a problem, but you never know. I think your write, im gonna be taering it apart....God help me. Thanks again.
      • #4
        Hello Billy;dom't be afraid of OMC carbs.My personal opionion they are the easiest on the market.However I think that you have adjustable low speed jets on your engine, if so screw them in all the way(seated lightly) counting the number of turns just to enable you to put them back where they where at when finished. other than that set the floats parellel with the carb. body take a can of spray carb cleaner and make sure all holes and orfices are clean install the carb kit and you are done.Hope this eases your mind some
        • #5
          Hi Billy I agree sounds like float and float valve time to me. If your motor is flooding out while running. Check the choke springs, make sure they are strong enough to hold choke open. Good luck.
          • #6
            thanks for the encouragement almost retired, I was really hoping It would be somthing stupid like a seal on a gas tank or something like that, not to thrilled about having to rip into this thing, but sounds like I might have too. O well I guess thats part of boating fun.
            • #7
              HI alcan, thanks for the advise. Befor I do anything I think Ill try, (when it warms up here)running it again, last season I noticed if I primed the baulb just enough to get some gas in the moter, it would run fine, but when I stop and sit a while with the motor off the gas will start to run out the motor, than when you start it up again, its flooded. I was just hoping that somehow while sitting, it fixed itself, yeh rite, no just thought id give it another shot before I dig in, cant hurt. Sorry my messages are so long, but heres one more question. This boat ran great last summer, we went up north (Mi.) towed the boat for about 4 hours, the moter was lifted up on the transom for travel. When we got there I noticed I forgot to unhook the gas line, thats when it started acting up. is that possibly what stuck the floats? Thanks for all the help guys, God bless
              • #8
                Hope u haven't dug-in yet. THERE IS one thing you can try. Get a bud to squeeze the primer bulb,while you gently tap the bowl of the carb. Many times this will jar the needle enough the seat it.
                "Did you hear about the guy whose whole left side was cut off? He's all
                right now."
                • #9
                  Yes 12footer's got the right idea. If you havn't service those carbs in a while now is a real good time. You might be able to obtain a manual at the libaray. Or by one, well worth the money. Just work slow take your time, no hurry when the weather is nasty,right? Good luck have fun.
                  • #10
                    Sounds like a needle valve or a fuel supply leak. Carb rebuild kits are easy to install, might just have a bad gasket or needle valve & seat. Don't be afraid.....look at the parts, forget the directions and replace what you see. Just keep it clean.There are certain fuel chambers that may cause a problem but this sounds like a fuel supply sealing problem not a mechanical one.Edited: Forgot the primer bulb. When in doubt, throw it out. They are only about $5.
                    • #11
                      AHHH, The plot thickins. Hey thanks for all the responds, I havnt dug in yet, wont till im absolutly sure Im ready, I will definattly try any trouble shoots first, such as the tapping on the carb idea, never know might get lucky. Hey is there a fuel pump on this thing that could be bad? Not sure it looks all vacume fed. Thanks again for all the help, this is really great, how it should be, fellow boaters helping each other out, too bad Ill never hit the waters with any of you. Hope I can return the favors some time. God bless!!
