• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Evinrude idle adjustment
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Evinrude idle adjustment
    I have a 1994 Evinrude 120. It idles at about 1000 rpm. Makes a nice "clunk" when shifting into gear at this rpm. Would like to idle down a little to lessen stress on lower unit. Throttle/shifting linkage is right. What else can I do to slow engine a little?Also wanted to re-torque heads...does anyone know what psi to use on head bolts?Any help would be great!
    Re: Evinrude idle adjustment
    Youre right. It's idleing too high. First disconnect the throttle cable. Locate the idle stop screw on the port side under the flywheel. Back the screw out to slow it down. This will allow the timer base to be retarded further. The idle speed adjustment is on the upper starboard side just under the flywheel. It is a black plastic piece with a plastic locking nut. Loosen the nut by hand and turn the handle clockwise to slow it down. This moves the timer base without changing the throttle adjustments. Tighten the nut to lock it in place and adjust the cable to match and reattach.There are good pictures and a better discription in your service manual.Good luck!
    • #3
      Follow Dhadley's method and drop about 200-250 rpm. As far as retorquing the heads, let engine sit out of water for a min. of 12 hrs. This will ensure it is cool and drained. Loosen all head bolts. The heads are marked with the proper torque sequence. Start with 10#, go to 15#, and finish with 20#.
      • #4
        Hey, thanks again for the good information. When I re-torque the heads how many ft lbs of torque should I apply to each head bolt? Thanks
