• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
1970 Johnson 6hp sea horse
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1970 Johnson 6hp sea horse
    My little motor sat for probably 4 years collecting dust.I cleaned up the diaphram, carburator. Spark plugs looked fairly new so I simply cleaned them up a bit (No rust or corrosion).Hooked a tank to it and the motor fired up on the 3rd pull and ran choked, but as soon as I take it off of choke it dies. It will not start while the choke is off but put it back on and it starts again and runs great (As well as expected choked)The impeller was replaced right before I placed it in storage and is pumping water out the exhaust.I plan to buy a carburator rebuild kit this evening and see if that helps. Should I also purchase a diaphram rebuilt kit, do they even sell those?The lean/rich knob was bumped at some point so it is not set right and I have to mess with it just to get it started in choke.I am sure the carb needs rebuilt, but is there anything else I should look at?Sorry for all the questions but I am uncertian what could be the problem other then the carb needs rebuilt (Gaskets etc...)Mark
    Re: 1970 Johnson 6hp sea horse
    Howdy, Snookerman.I think you are on the right track. One thing to check before you tear down the carb again.Pull the fuel input line off of the carb and put it in a plastic bottle. Pull her through a time or two and ensure that you are getting healthy spurts of fuel from the pump.Red sky at night. . .JB
    sigpic
    • #3
      Snookerman..... If pumping the fuel primer bulb (in effect, acting the part of a fuel pump) solves the problem, you have either a fuel pump problem or a air/fuel leak somewhere. If pumping that bulb makes no improvement, the carburetor is fouled/clogged and will require cleaning and rebuilding.
      • #4
        Hello and thanks for the replies.I rebuilt the carb this morning and replaced the spark plugs. And it had no improvement.I have checked the fuel input line into the carb and it is squirting fuel out pretty good.I see loads of fuel in my carb after I get done cranking on it so I am thinking it is flooding out for some reason. It still only cranks while the choke is on, but now it is even harder to get it going since I rebuilt the carb.I guess I will start checking for air leaks since I see no fuel dripping to indicate a fuel leak.Any other ideas or moral support? ;-)Mark
        • #5
          An update I have bypassed the diaphram and ran the gasline straight into the carb inlet and that didn't change much except the ball will not stay hard now and the carb bowl empties out while I am cranking on it. It is no better though and it now spits once in a while when I am cranking on it.I know it runs because it will run once in a while for like 5 seconds off idle now then just dies and will not restart right away even choked.Mark
          • #6
            I think I have found the problem....I took the fuel connector off the motor and hooked a clear line from it to the diaphram/pump and started pumping the primer ball but guess what. The fuel does not even go up to the motor and has air pockets all in the fuel line. Does this indicate a air leak within the fuel tank itself? If I pump it up, the fuel will go half way up to the motor but will not go all the way before the ball gets hard. So I am thinking it isn't nothing on my motor at all causing the problems but actually the tank itself. Any idea?Mark
            • #7
              snookerman1air bubles in the fuel line would say to me that there is an air leak, Lines, bulb, fittings, pickup, somewhere. Not letting the gas into the carb, says that the carb is either full of gas thus the floats is holding the nedle valve closed, or it is stuck or clogged!Richard
              • #8
                Ok this will be my last post concerning this.I bought a new tank and primerball today and same problem, so I took the carb off one more time and took it apart. I thought I had cleaned it cleanly so I did a quick once over, then I noticed some tiny holes in the carb so I decided to make a tiny tool that could clean those holes and sure enough one was clogged. As soon as I put it back on the motor and tried it, it was working correctly! I had to do a little adjusting of the rich/lean knob but all went well :-)I thank all of you for sticking to your story that the carb is probably clogged ;-)I plan on testing it out on a local lake SundayMark
