• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
1983 70 hp Johnson
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1983 70 hp Johnson
    Hope someone can help. I am rebuilding thismotor that has sat for 12 years and for the most part am done, except the engine when itstarts does not want to stay started and willdie shortly after starting. I have rebuiltthe fuel pump, put in new gas lines, havenew tanks, new plugs, cleaned the carbs. anysuggestions on how to help this motor keeprunning? It doesnt want to idle at high orlow. It runs if I keep priming it.thanks, Butch
    Re: 1983 70 hp Johnson
    Hi Butch, My money is on the fuel pumps. Those OMC pumps can be a bit tricky and only go together one way. One quick test to make sure the check valves are in right and operating is to blow in from one side of the pump and then the other. It'll only blow thorugh one way - the direction of the fuel flow. If it blows through in both directions, then somethings amiss.- Scott
    Share A Project Page for 1971 GW Invader Banchie 13
    http://www.shareaproject.com/pages/p...,p,433,00.html
    Share A Project Page for 1976 American 18
    http://www.shareaproject.com/pages/p...,p,404,00.html
    Share A Project Page for 1974 American 15
    http://www.shareaproject.com/pages/p...,p,405,00.html
