• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Old evinrude 7.5 fleetwin
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Old evinrude 7.5 fleetwin
    Hi, i have a old evinrude 7.5 hp 2 clylinder engien. i am not at my house now but ill get the serial # when i get home, my question is, where are the water intake for the water cooling system? thanks
    Re: Old evinrude 7.5 fleetwin
    i forgot, i dont have a manual, where can i get one? and can i run it on a leaner oil, i am currently running it on a 16 to 1 ratio, i was thinking maby jump to 32 or 40? thanks
    • #3
      Hi Nitro BoyFor manuals click on the link above called "Manuals" (always support our sponsors).Another place to look is http://www.evinrude.com and click on "Docktalk". In there you will find how to source manuals and you can also look up the year of your motor once you have the model number.
      • #4
        all models are equipped with a rubber impeller which is mounted on and driven by the drive shaft in the lower unit, water enters the lower unit gearcase through an opening in the rear of the antiventilation plate
        • #5
          • #6
            Allrighty, i got the serial number, it is,7518-39034 edit: i got the date, its a 1955 ( wow, thats old) and i cant find any manuals...., where is the antiventalation plate located? what dose it look like? how much would it be worth?
            • #7
              Hi Nitro Boy7518 must be the model number, which makes the year 1955. The rest is the serial number.
              • #8
                Hi NitroBoy, Your 1955 Fleetwin is a good little motor. The water intake is through a screen in the rear of the lower unit, on the leading face of the exhaust outlet. Most of the water exits through the exhaust, but some will come out the exhaust relief hole, about midway up the rear of the leg of the motor. You should have a good solid spray, like a faucet without an aerator. Make sure you run that motor at 25:1 on the fuel/oil mix. I just rebuilt a similar motor with a new block due to the old block having been "ventilated" by flying connecting rod chunks - caused by running it at 50:1. As for worth, I recently picked up a complete one in need of a tune-up for $75.00. Evinrude built a lot of them - the serial number portion of yours being over 39,000. Let me know if you need any parts for it, as I have some leftover odds and ends from my recent project...- Scott
                Share A Project Page for 1971 GW Invader Banchie 13
                http://www.shareaproject.com/pages/p...,p,433,00.html
                Share A Project Page for 1976 American 18
                http://www.shareaproject.com/pages/p...,p,404,00.html
                Share A Project Page for 1974 American 15
                http://www.shareaproject.com/pages/p...,p,405,00.html
                • #9
                  do you have any of the original spark plugs? mine all have the bar bent out of shape..., also you know the intake pipes on either side of the engien? are there air filters in there? when i test ran it in a garbage pail, i ran it for like 30 minuets, then i hosed the thing off, and ran it in a bucked wiht clean water for like 5 seconds to wash out the water intake. am i better off running it and tunig it in my garbage pail, or running it wiht a hose attachment? thanks again
                  • #10
                    Hi NitroBoyThe spark plugs you can get at any good auto parts store. Champion J4C is the new # this replaces the J4J. Those intake pipes are Air silencers, they are basicly mufflers. They are to make the motor more quite. They filter nothing, and unless you can see a blockage they do not require service. Making final adjustments is always done in a tank,etc. The water creates back presure you will need for proper adjustment.
