• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
  • **** The forums will be undergoing maintenance tonight approximately 9:30pm-midnight MDT. Thank you for your patience during this time. ****
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
50 HP Evinrude 1983
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 50 HP Evinrude 1983
    I was looking at a 50 Hp 1983 Evinrude i am maybe going to buy.Does anybody have experince with this type/model. What shall i look fore except for compression and water in lower unit. It is running and iddling fine.Is there any weak points on this model ?Appreciate your help
    Re: 50 HP Evinrude 1983
    Howdy G. Dane.The OMC loop charged twin and triple, introduced around 1970, are truly great engines.If it is a VRO engine, be sure the pump is working properly. Also, remove, clean and reinstall the ground cable to the block at least once per year. It is usually bolted down to a steel plate, rather than to the alloy block itself and corrosion gan get started under the connection.Good luck. It's a great engine.Red sky at night.. .JB
    sigpic
    • #3
      Thanks for your advise JB. I think i will buy it. I can get for 750 USD, it seems like a very favourable price, dont you think.
      • #4
        Another question JB :I have a 1984 35HP, fine engine too, dumb question maybee, but is it a crossflow or a looper ? I know carb. and exhaust is opposite og eachother - but ?
        • #5
          Howdy G.Dane. 750USD is a good price for that 50, anywhere.I think your 35 is a cross flow engine. I don't remember when the little three cylinder 25/35 looper was introduced, but if it's a twin it is cross flow, if it's a triple, it is a looper.Red sky at night. . .JB
          sigpic
          • #6
            I went to see and hear the 50 HP. The compression was 120 on both, warm condition - isnt it a bit low ? My own 35Hp has 125 cold.Looking at bolts and screws under hood, it looked like motor had been in salt water. The owner had it for 6 yrs and it was not in his time, he says. The motor fired right up, ran fine ( earmuffs without load ) and iddled smooth. However it gave a clacking sound, now and then iddling, disappearing immediately when opening throttle. When crancking by hand, finding piston deadpionts, it seemed as the one rodbearing had more play ( double ) than other. Can it run 6 yrs with a damaged rod bearing, or am i too suspecious ?
            • #7
              BUMPCan anyone give me an advise ?Thanks
              • #8
                Howdy, G Dane. If you are suspicious, pass on it.Red sky at night. . .JB
                sigpic
