• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
88 spl johnson schematic
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 88 spl johnson schematic
    does anyone have a schematic for the 88hp johnson with a vro tank. How reliable is the vro and There is no warning buzzer on my boat for the vro, is it needed even if you put a little oil in your gas anyway. Sorry for allthe questions.
    Re: 88 spl johnson schematic
    Some love the vro and some dont. I personally like to disconnect them and run 50:1 mix so their is no powerhead failure due to lack of oil. Are you shure you dont have the warning horn or is it just broken?? Its part of the VRO system.What kind of schematic do you want? One of the VRO system?
    • #3
      88 Special not factory equipt with VRO,you have a model number.
      Help somebody every day, if you can.
      • #4
        just the motor schematic. If there is a horn where is it? Theres two wires comming out of the tank to the motor but what makes the noise?
        • #5
          The horn is in one of two places..In the remote control (shifter) or under the dash in the accessory wiring. If you get a "beeping" horn you have a low oil condition (under 1/4 tank). If you get a continuous horn its an overheat condition.You need to check to make sure the horn is working. Find the overheat sensors mounted in the block (should have two wires). Disconnect where its joined and turn the key on and ground the wire to the block..The horn should sound.
          • #6
            Thanks Trent I'll give it a shot.
