• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Shock assist manual tilt.
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Shock assist manual tilt.
    I have an Evinrude 40hp tiller elect. mod E40REESR. The shock is not working properly. The thing lost its assist. Its very hard to tilt motor up. I have no imfo on servicing this unit in any of my manuals. Can anyone shed some lite on me? Are they repairable? There is no visible damage, no fluid leaking. Thanks.
    Re: Shock assist manual tilt.
    There are three places that could be causing your trouble.First look at the cable that makes that unit work.Looks knarly,then remove it from where it screws into the tilt assist unit and ,watching your head,try to make it work by just pulling on the dissasembled cable.No luck? Then remove the upper tilt pin.Sounds easy but these things are often seized so be prepared.Once the pin is out lift the motor up and down by hand.Easy motion,with only a little effort,means assist unit.A good deal of effort means you need to clean the tilt tube bushings.
    • #3
      Thank you hondon.The cable and lever seem to be in good working order. I have the shock unit removed from transom clamp. How do I disconect cable from unit? I tried to open allen screws at top and bottom. They are real tight, I didn't sucede. I haven't messed anything up yet. I have serched all my manuals,parts and accessories catalogs,I have no imfo on this thing. What do I need to do to repair it? It acts like it has air in it, it gurggles a little. When I pull up on piston it's hard at first, then it gets a easier. Thank you tons!
      • #4
        Since you have decided to your satisfaction that the tilt assist unit has failed,[and they often do]there is nothing that I am aware of to repair it.You will need to buy a complete tilt unit and the vintage you describe may not allow you to remove that cable.I beleive that came a few years later.Look for a knurled nut at the assist end of that cable.
        • #5
          hondon thank you for the help. I have unscrewed the knerled ring. Mybe I just need to be a little more agressive with it. I guess thats why I couldn't find any imfo on the repair of this unit. Looks like it's off to the parts store for me. Thanks again!
