I've got some problems with a 68 rude starflite and was hoping someone could help me out:<br />One night the other week, was running back in from a fishing trip, and the boat sort of lurched forward. The motor sounded fine, ie it didn't miss or rev up, but it felt like someone threw the boat into nuetral and then back to 3/4 throttle again. The problem recurred a couple more times and I brought the boat off plane and cruised in with no more problems. <br />Mentioned the situation to a friend of mine, who suggested I may have broken the rubber sleeve inside the prop, and that was slipping. Got that replaced and headed back out for another day of fishing. Boat ran great to the fishing grounds and idled well while we were fishing, but on the way in the same problem recurred. Shortly after I revved up onto plane, the slipping/missing occured. Once it occurs, it only occurs more frequently until you take the boat off plane. <br /><br />So here's the summary: <br />1. The motor sounds great 4/5s of the fishing trip. <br />2. After it's hot, there is some slip or miss that causes the boat to slow down for an instant before catching back on again.<br />3. the problem does not seem to be completely torque related (as my ignorant self would have thought). It would seem much more logical to me if the slip occured every time I put a lot of pressure on the motor, not just after it's been running for several hours.<br />4. the problem does not get worse over successive trips, just over the same duration each trip.<br />5. the engine fast idles fine even when the problem has occured recently.<br /><br />Any help would be much appreciated.<br />thanks<br />ed
