Hey guys, trying to replace the propeller shaft seal on my 1976 johnson 9.9 (10E76G). I cannot remove the bearing housing as use in salt water seems to have it frozen in. Leeroys Ramblings mentions using a puller or slide hammer with a screw on the end to screw into the seal and tap with a hammer to get it moving but I cannot find any type of puller like this. Is there any other way to get these seals out without going to a pro to have the bearing housing pulled as I am at least 2 hours away from a marine mechanic. Any thoughts or suggestions would be much appreciated
Thanks in advance
Thanks in advance
