Over the weekended my tilt trim started to act up. It would work great then stop and didn't matter if it was up or down. When I would push the up or down button I could hear the relay clicking. A few time it just started working but the other times it didn't. I started to look for lose wires or something that would be wrong with the wiring and couldn't find anything. So I started to tap on the sending unit by the trim motor and everything started working. So ever time it happened after that I would just go back and tap on the sender and it would start working. After pulling it on shore I was looking at the sender and found it was gummed up so I cleaned it of and sprayed some wd40 on it. As soon as I did that the trim and tilt stopped working and is stuck in the up position.
I'm new to outboard motors and am not sure where to start in getting it fixed. From what i understand the sender only goes to the trim gauge (which I do not have)and should have nothing to do with this ?
Thanks for your help
