waterbaby1917
- May 15, 2014
- 6
Hello all, I am new to iboats and fairly new to boat repair. I have been working on a rebuild of my 1984 Evinrude XP 150. I'm close to having all the gaskets replaced with only the carbs and intake left. She starts up just fine, but won't run for long (guessing once carbs are empty of fuel). I have replaced all of the fuel lines and primer bulb as well, so with the exception of an carb issue I'm guessing that this is a fuel pump issue. It has the original 1984 VRO pump on it, but has had the oil side disconnected for years (bought that way and was told oil side went bad and tank was removed). My question is can I just replace it with a regular fuel pump or does anyone know if it can be rebuilt without breaking the bank. Have had no luck researching online and any help would be appreciated. Pump is the vro 150 174128, believe this the the first year they put these on.
