Hi. Everyone. Having a major idling problem I really need some help with. Basically hard start, mainly cold but sometimes warm, stalls at idle, almost all the time. And sometimes when switching gears a real pain when tring to dock. I have had the motor for 4 years now and basically had the same problems all along. Cruising is ok wot is 5500. Was told that is good.
Here is what I have done
Set all carb linkages many times, Plugs, wires, power pack, stator, and all that goes with it. Sorry don't remember all there parts they put in that work with stator.compression 125-130 on all 4 cylinders, spark is strong 3/8 on all, new primer bulb, pumping doesn't help, new choke primer, New thermostats 2 sets in 2 year had carbs done 4 years ago when bought it, was told last year that they where clean and needed nothing. ( and nothin was done with them) I had the dealer set timing at end on last season, so didn't get to much time running. But they also told me they set it on muffs, thought need to be in the water or test tank?? True? False? I'm lost? I am going down this weekend to try and resolve this once and for all, before the holiday. I did forget to mention it runs better on muffs then in the water. So I was going to run in a test tank this weekend to try and resolve problem and do any repairs.
Thanks in advance
Thanks in advance
