Hi ya'll, picked up a used ranger with an 1984 johnson gt-150. need to know how to adjust the timing on it without starting it if possible. all help would be very much appreciated. model # is j 150stlcrd. 3-carbs. looks as though the previous owner changed the head on it as it is black, and not white, as i remember the original was. is the idle screw the timing adjustment as well? and to adjust the timing, do i need to disconnect the throttle and shifter? all help would be very much appreciated, thank you.
