I am replacing the impeller on my 1963 evinrude 18hp fastwin 18302L. I have the Seloc repair manual for the motor. The first step in installing the impeller according to the manual is to apply a coating of sealer to the upper surface of the lower unit. Then it says to install the water pump base plate. So what is considered the upper surface of the lower unit? There is no picture that shows what the upper surface is in the manual.
