tj06civiclx
- May 24, 2013
- 17
So on the first trip out this year the boat hit a rock that was hidden under the water. It seems to have hit the lower unit.
The motor is still running fine, and shifting fine, there is no oil leaking into the water. But we noticed water leaking out of where the lower unit connects to the midsection when the engine is raised out of the water. I don't remember water coming out of there before?
Wondering where to go from here... Is there a gasket that goes in between the midsection and lower unit? Does water usually leak out from there?
Thanks for any info!
Tim :facepalm:
Tim :facepalm:
