mypontoonboat
- May 12, 2014
- 1
I lost spark on the bottom cylinder of my 75hp Johnson. I swapped wires on the coil and got fire out the coil that was not working so I know coils are good. I installed a new power pack and still have no spark. Compression is 132 on all 3 cylinders. Is this the stator or timing base? How do I found out without having to buy both. Motor had cranked ran for a second cut off then I had no fire on bottom cylinder. The starter is turning over the motor plenty fast enough and I changing the power pack did not fixed it the problem. Please help! I looked over the wires going under the flywheel could not find any damage.
