Hello all here's a brief description of what im working with;
I have a 1976 Johnson 135 outboard, ive put a lot of work into it and when I put it away for the winter last year everything was working great and smooth. This year as I was prepping it the control lever would not go into reverse, I disconnected it from the motor and still wouldn't go. I took the control box apart everything was intact and looking fine so I regreased the important parts put it back together and it was working fine again. After playing around with it the shifting became stiff and would not let me put the lever in reverse again (cable still disconnected from the motor). Took it apart again same thing, everything looked fine and put it back together and worked fine again. I was moving it through the movements for awhile and it was working fine. Hooked it back up to the motor still working fine. Brought it to a pond to test it on the water and wouldn't go into reverse again. Im about to take it back apart very slowly and different way to see if maybe the ball on the shifter popped out. If anyone has any insight on what might be causing it would be greatly appreciated.
