I just bought a 1995 40 hp Johnson. It was converted to a tiller, the oil injection has been removed and now just uses a 50:1 fuel mix. I just used it for the first time and it worked great for about 30 seconds. Got on plane a was cruising along. I slowed down for a second to tell my dad to hold on to his hat and when i tried to throttle up again the power was not there. It seemed to have the power of a 10 hp. A day later it seemed to drop down again in power about an 8 hp. It starts up and idles well. When I bought it the compression was 150 in both cylinders. It uses an electric start and electric choke. I have it on an AW 1860 mod v alumacraft jon. The gas was brand new and I just changer lower unit lube. Also installed new plugs. My friend checked spark and said it was good. It is my first boat and outboard. Any help would be greatly appreciated.
