1972 Johnson 100 hp model number 100ESL72R. I have not checked compression yet but believe it to be good as for when the engine ran it runs like a champ, takes my little 16 ft fish/ski up on plane fast and scoots across the water. But plan to get a tester today and check it. Ok if any of you have been following on my other post I replaced the battery cables per troubleshooting using the CDI guide. And charged the battery 100% last night. Went out this morning connected the battery cables to the battery squeezed the bulb put the choke on and put the control in start and turned the key and it fired right up, was starting to die and I went back and cut the choke off and it picked back up. Got up to the control box to start revving up the engine and it died. Turned the key over and it started again ran a few seconds and died. Turned it over again started and died, tried the fourth time and now it doesn't start. Had my wife turn the key while I had a spark plug out to see if it was getting spark, top left plug no spark and top right plug no spark now. I tested the clipper circuit and rectifier and they are good. I did the first test of the power pack and I believe it's bad, I got .1 aps from terminal block9 to power pack black wire to coil, says should be no more than .7 amps anything higher or low amps it's bad. Is this correct? This motor has ran before then things started going bad, rectifier, clipper circuit (missing), shift diode, shift switch. Replaced all but shift switch (hooked up a toggle switch). Changed spark plugs. I purchased a stator/distributer for a good price off ebay because I think the stator is bad but not sure as I haven't checked it while running. Doing the bench test I believe it's bad. Would that cause no spark?
