I have a 1994 johnson 175 oceanrunner and recently i just put a new throttle cable I just now found out that one cable give gas and the other engages the revers and foreword. after i put the new cable on i noticed that the prop would still spin while in neutral so i called the boat shop and he told he to adjust the cable that engages the fw and rev. so i did and it fixed the problem with the prop spinning but now when i put it in rev. it wont engage to go revers. it still give it the gas but int wont engage but will engage in foreword. do i need to still do some adjusting?? does someone have a video or something i can check out?? NEED HELP!!!:facepalm:
