i had to manually use the trim buttons on the back of the motor to raise and lower the motor. went to mech. and he said to manually connect the wires at the throttle cable. i did and the trim button on the throttle would lower the motor but not raise. i accidentally touched what i think was the ground wire to a hot wire and now have no power at the motor to raise or lower. also no power at the key to start the motor. did i blow a fuse and if so where is the fuse?
