Hi.
I'm working on a 6 hp Johnson 4-stroke, 2004.
I've got it running in a barrel but I notice there's no water coming from the tell-tale hole in the lower cover.
The 4-stoke is new to me. Should I expect to see water peeing out the hole as in a 2-stroke?
There is some water being sprayed out the upper exhaust but very little.
And, the engine block does not get that hot, at least not in the barrel.
Maybe all this indicates it's time to change the water pump impeller.
J
J
