Okay y'all I need some help. I have a 2001 Johnson 150. A year ago after it was at a good hot operated temperature and I turned it off it wouldn't start back up. Put it the shop when I was deployed. Had the works done. New plugs, wires, power pack, flywheel, stator, water pump, and rebuilt carbs. Family ran it to keep it up and it ran great. January I took it out and after 30 minutes of running it killed and wouldn't start back up. Found my flywheel was scrapped the top of my stator. replaced the stator and fixed the fly wheel. Now it will only run for 5 seconds and kill before it comes out of high idle. Then after a couple tries it wont even run at all and sounds like there's no compression but I had a compression test done and all cylinders tested good. Any ideas?
