crankbait cowboy
- Mar 25, 2013
- 570
long story shrt, i have a 1973 johnson v4 115 horse i am in process of getting running. last dec checked compression in 20 below weather and got 95 psi on 3 cylinders and 85 on other. this engine had been sitting idle for years.i had fog oiled carbs and cylinder holes a bit , held carbs wide open,and all plugs out . it was cold and cranking was not great so i felt i would get better numbers with better weather for cranking and engine a bit looser. well tonight i tried again and am a bit befuddled. i did everything exactly the same and my numbers now are 75 on 3 and 50 on other.
3 questions, any ideas as to why my numbers fell off ( all i can think of , is poor battery cables, but they are same as ones used before) am i doing something wrong? and probably most importantly these latest numbers are below acceptable aren't they? any input would be greatly appreciated and thanks
