lancelotlink
- May 3, 2014
- 3
I have a 78 jonny that drips fuel while it's running, but after i shut it down it just pours out of the butterfly valve.
Seems to run rich at idle, lots of smoke. I have adjusted the floats to try and compensate to little effect.
Almost seems like there's too much fuel pressure. I will do a pressure test this weekend.
Anyone heard of this problem before? I have rebuilt the carbs, I have an original FSM.
Thanks in advance.
I found a prior poster with the same problem, there was no resolution posted.
Thanks in advance.
