Hi. I've posted on this forum a few times before about this engine and a few others and always got a great response, so i figured this is worth a shoot. I've been using this motor about two summers now and what little rubber was left of the cowl mounts has simply turned to dust at this point. this has caused the motor to get a million little rattles well running and has destroyed my paint job on the fuel mix plate at the front, it also caused the 2 pegs in the cowl to get busted off. I'm not really sure how to fix the pegs as one of them is lost completely and you cant weld this cast metal that the cowl is made of, any suggestions? what i'm really after however is the rubber itself. i need the 3 little rubber stops that go in the cowl and the gasket-type trim around the fuel mix plate and any other trim that may have been there but has fallen off years ago. is there any place that sells re-pro rubber for this outboard?
The other issue i have is when i checked the oil in the lower end this year there was very little left and it was mostly filled with water. the lower seals are obviously shot but i can not find any replacements on this site and i seem to remember something about having to remove the power head to remove the lower end on these motors. So is it possible to get these parts and where? does the power head have to come off, and if so where do i get new seals for that, as there most likely shot to? and finally is it even worth it or should i just top up the oil and drain the water every month?
