1977 Johnson 35hp Seahorse 35EL77C
I've had this motor for over a month now and I have been having an issue starting it up. I should re-phrase it, I am having an issue re-starting it after it has been running. From a cold start it starts just fine. No excessive cranking needed to get it started and idling. The issue here is that after it has been started, warmed up, shut down, and left off for a few minutes it will not start back up. If I try to start it it will just crank with no sign of wanting to start.
I prime the bulb and it gets hard and still won't start.
Fuel tank is properly venting (no signs of it getting sucked into itself).
Plugs are new and have been swapped out and still the same issue.
No fuel leaks.
Water pump kit I just changed out water flows nicely when the motor is running.
Battery is new.
If I try to start it back up right after shutting it off it will start up fine. It has to sit for quite a while before it will want to start again. When started it will run with no issues. I'm new to outboards (handy with automobile engines) so let me know if I have overlooked anything.
No fuel leaks.
Battery is new.
