Have 2003 pontoon with Honda controls. Are there any adapters available to hook up 1977 70 hp evinrude? If not, what is most economical solution. Original control not going into reverse.
I have never heard of a Honda adapter. The original controls should be cable operated. Have you removed the cowl and looked to see if the cable is moving the shift lever? Is this a new to you motor?
