The other 5 cylinders have between 80-90 psi.
The motor has been sitting for a while.
I'm wondering since compression in 1 cylinder is that low is it a broken reed? Dropped cylinder?
Seems to be too low for a stuck ring?
I will be taking off the head tomorrow to check the cylinder but wanted some feedback ad if it was low in the 60-70 psi range I would assume stuck ring but doesn't seem the case.
Thanks in advance!
Thanks in advance!
