Re: Skeg removal
With all of the screws removed, including that philips screw... tap it with a hammer such as if the lower unit backed into the hammer. The skeg should just fall off.
If you're having a problem removing the screws (you didn't mention it), use a hand held impact screwdriver, available at Sears, any auto parts store to mention a couple.
