New thermostats and gaskets Both done. New water pump done, tell tale excellent. Hoses clear done. Here's the PROBLEM. One or the other cylinder will run hot, switched thermostats 1 HOT 1 NOT. took out thermostat, Fine, switched thermostats again other cylinder hot other fine, and so on and so on and so on!!!!!!! I did about 12 combinations of changing and removing thermostats, Seems like no matter what I do (one or the other) cylinder will run hot? What's the deal? Perplexed and confused?
