jsteverson
- May 3, 2014
- 5
Purchased a very clean 82 9.9 hp Johnson but don't know the motors history. I replaced the water pump and lower unit oil when first got it to the garage. Then the next day I noticed a little oil coming from the prop seal, so replaced that also. Finally got it out on the lake and noticed after awhile at full throttle it will "Slip" and rev high then go back into gear. No strange noises or grinding. So my first thought was spun prop, took prop off marked and took it back out. After getting it to do it again, I took the prop off and marks are still aligned. :grumpy: But what I did notice is it only will only slip if I'm at full throttle turning left, which leads me to think somethings not lined up correctly and its not a actual gear slipping or clutch dog? Any help would be great I don't know a lot about outboards but I'm sure there's someone that knows something I don't. Thanks in advance!
