Having replaced the water pump there is no water coming up to the top of the head at the thermostat when the motor is running, but when I take off the flywheel, remove spark plugs and attach a drill to turn the motor water does flow up. Is there a back pressure of some kind that prevents upward water flow when the motor is running? Thanks.
