Re: water pump spline grease
By design, the impeller is lubricated by water alone. Which means it should require no other lubrication because it should never be turning when not in water. Having said that, there are some people that think you should lube at first install. Some people don't. I personally do use some type of lube but it's really just for ease of getting impeller veins to slide into housing. Just about any type of lube would work, it's gonna get washed away anyhow. I just use plain ole Vaseline.
