speedingsilverbullet
- Sep 26, 2011
- 3
Hello everyone,
I have a 1984 Johnson 25hp that I'm trying to get back in good running order. The motor has a funny problem being that when you are at an idle in forward and you give it some throttle quick and then go right back to idle it will backfire and stall out. It will sometimes randomly do it, without the quick throttle motion, when you are just idling in forward gear. Adjusting the low speed doesn't help the situation either. The carburetor has just been gone through, float level is set properly, Compression is 122psi on cylinder#1 and 129psi on cylinder#2. I have indexed the flywheel and checked for erratic ignition which is looking good. I tend to think its a fuel problem but I would think opening the low speed adjustment would remedy the situation if that was the case. Does anyone have any suggestions as to where I should go next?
Thanks in advance.
Thanks in advance.
