Just received a new (to me) 1958 Johnson 35 HP (RDS 20 I believe) and went through most things in hopes of putting her in the water this weekend-
Was told it was water ready so was not expecting to do too much.
It started up easily and sounded to run real well, but was not seeing water expelled and am wondering if this is because it is not circulating and pump needs work or if this is normal because it has a thermostat..?
I have read some online and have found some that say it does have a thermostat and others that say it should kick water right away.
Any helpful information would be great!
Thanks
Thanks
