Johnson 1983 90 hp. I recently replaced my tilt & trim motor, every thing went fine. Once complete, I ran a few times and then it quit. Checked the voltage coming form the relay box I got 12.7 volts one way and nothing the other. I checked the relays and found one badly corroded. Changed it out with a used one. Unit ran good twice and then quit. I could not get any voltage out of the box. I replaced both relays with new ones. I still get no voltage out of the box. I checked the voltage going in the box and get 12.7 volts. I checked the fuse it is good also checked voltage through the fuse and I get 12.7 volts through the fuse. There are only three other things tied into the box. The operating switch, a gauge, and a limit switch. Any suggestions?
