Motor was running a little ruff, but runing no problem. I removed the plugs to test for spark and notice they were wet. Had a spark when testing off the block. I didn't use an air gap tester (didn't have, do now). After turning the motor over a few times the power light on the dash turned off and the boat will not turn over now. A couple times the light came back on, but when I try to turn it over I can hear the starter motor click quickly then the light turns off and I'm back to waiting again. Is this possible bad started solenoid or worse the pulse pack. I haven't notice any burnt fuses or loose wires. Any help would be appreciated. Thanks,
