All right gentlemen, I purchased the new Brp fuel pump kit for my 235 that I am building. My original pumps were completely ate up. All the metal in the pumps was crust and dust. So, in this kit, I have 2 pumps with the same #........ 438559. But they each have a different sub #. One is 15-L-1L and the other is 16-I-1M. The instructions don't indicate what goes where(which one is the pump that gets the tank line and which one gets it's inlet from the outlet of the first pump). Or does it even matter at all? You know, I completely took apart a set of 82 or 83 pumps and compared them. They were identical on the inside. Same spring, diaphram, gasket etc. What gives here? I thought one is the pusher and the other the puller? Just looking for some clarification here.
If anyone has the proper info for me, I will using the upper pump as the one from the tank. The lower will get its feed from above. Thanks ahead of time
Keith
Keith
