skeeterss1
- May 1, 2014
- 2
I recently bought a boat with a 50 hp 'rude and I've been having issues with it losing power at higher rpm's. It starts and idles great but after running for a while at speed it falls on its face and sounds like its starving for fuel. It will get the boat up on plane fine and 1-10 mins later it drops rpm's and won't go over about 6mph. After the problem starts if you let it idle for a minute and go back to WOT it runs perfect again but only for a minute at best and goes back to low power. When the issue occurred the first time I tried pumping the bulb to see if that would help and it was hard as a rock, I couldn't budge it. It never has any issue running at low rpm's or even running at max high idle just no power at higher rpm's in gear. I checked the fuel filter which was clean and don't know what direction to go next. I'm an auto mechanic but don't have much experience with outboards. Any help would be much appreciated, Thanks in advance.
