1967' 100 hp johnson (V4TL-13A) just replaced shift wire/cable, oil retainers. water pump. Had boat running off a hose in the front yard. Everything was working great. First start in over a year so I decided to let it run till it was warm. About 5 minutes into warming it up it just died. Motor isnt hot or over heated, the ignition light comes on with the key, and I can here the choke engage with the switch, but it will not even turn over. Battery had a full charge when I started. I tested it after it died I still had 13v. Any advice were/how to proceed to find my issue/s. Thanks
