Mitchsky
- Apr 30, 2014
- 2
Hi.
If I leave the battery hooked up while boating, the motor seems to drain the battery.
If I only use the battery for starting and then unhook it, then the battery seems unaffected.
I know that I need a new solenoid because we have to tap it to get the motor to start.
Can this solenoid cause the battery drain?
Is there a voltage regulator, is this the same thing as the rectifier, and is this what they do?
I would like to take the kids on the lake without any surprises this year!
Thanks.
Thanks.
