There is one hidden screw under the trim tab.
There is a screw that you can see to remove the trim tab.-----------Then you will find one more screw hidden now as stated before. The shift rod needs to be disconnected near the lower carburetor / under the starter,----7/16 " socket required for that.
Did you look at the site in post #8?
Make sure the impeller key is there. I grease the inside of the impeller housing....makes getting the impeller in there easier. Make sure the fins are bent the correct direction when putting the impeller in the housing.
Check the water pump housing gasket(assuming that your motor calls for a gasket)...if it's bad you can grab some generic gasket material locally and make your own. Make sure the O-ring is present on the drive shaft. Its in a groove near the top of the shaft.
