Dissasembled gearcase, new pump, new clutch dog, new seals, checked solenoids- 5.5 ohms, plunger slightly below top of solenoid, proper voltage to solenoid leads, N-power green, D- no power, R- power green and blue, new type C oil, still can't find neutral, have only tested on a hose. If reverse is working, shouldn't both solenoids be functioning properly? Any suggestions would be greatly appreceated. This project motor has been in the works since last summer, Thanks for all the great advice that has kept me pushing forward.
