I just bought a j90tlcur motor. It was off the guys boat and he wasn't able to prove it runs. I bought it as is. I put it on my stand and did a compression check. It was good. It has a remote oil tank and vro pump. I hear that the oil tank set up is no good and I should mix my own gas. Is this true? Before I spend any more on the motor that I haven't seen run I'd like to run it. Any tips on what to do as far as making sure the oil is getting to the motor. I never had an oil injection set up and I don't want to blow it up on the initial test. Should I change it over and mix my own gas and if so how?
