scotterman
- May 1, 2010
- 9
So I have a 1990 40hp johnson that I just replaced the lower unit oil. There was a little bit of water in there and the oil was dirty(no metal shavings though). The engine runs great but will now not engage into forward or reverse. Maybe something came loose at the control box? I checked under the carb and the linkage is connected there. The shifter seems too easy to move when trying to go into gear. When I put it in forward or reverse it just revs up..please help!! Thank you!!
