1990 Evinrude 200 hp, water pump & thermostats changed out, not peeing!! No pressure!
I just changed out my water pump with a complete kit, housing, etc. & replaced the thermostats. The water pressure on the old pump ran about 10 psi @ WOT, & occasionally the temp alarm would beep, so in order to be safe, I changed it out.
NOW, no water pressure or pee stream. Flushed all lines, old impeller was in good shape, no broken vanes, etc. no salt water running, blew out all passages, checked flow of by-pass & pee lines. Can't even get a stream with ear muffs on at 40 psi!!.
I must have missed the hole when lining up the foot!! Does anyone have any tricks, short cuts or suggestions how I can fix this "issue"?? i.e., having no help, have to lift foot my self, tried using a floor jack, helped some. Anybody got any drawings of a stand. On another thread, somebody mentioned building a holder out of 2x6's..
The toughest thing to getting it back together was lining up the shift rod coupler under the carbs!! The foot seemed to slip right on, Duh, go figure??:blue:
